So I completed a CU change on Friday, (It was a bitch btw) and once I was done, when I turned the power back on, switched the pendant on above my head in the hallway and heard a crackling sound coming from the pendant.
I switched the power back off and took the lamp out, to see that it was smoking because there was a strange grease like substance that had been dripping down the flex of the pendant and into the lamp holder, shorting across the pins of the lamp.
I unscrewed the pendant and found what is in the picture I have attached.
Confused, I took up the floorboards above the fitting upstairs, expecting to find some sort of decomposing animal, but found absolutely nothing, totally dry, nothing out of the ordinary.
The property has been rewired as recently as the ‘new colours’ and after stripping the cables back in the fitting a little way, found them to be fine and no sign of any grease or moisture.
Along with having no idea where the hell this grease like stuff could have come from, even if it was sitting in the pendant screw cap like it is, how did it manage to find its way down the flex to such excess, that it’s flooded the lamp holder enough to short the lamp out ?
It’s not like the fitting has been in an incredibly greasy kitchen for years, it’s in the damn hallway!
Look forward to any theories ?
