what outdoor alternatives to SWA... | on ElectriciansForums
Discuss what outdoor alternatives to SWA... in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
salisbury spark
Need to run a supply for a CCU outside on a wall(130 feet). Customer doesnt want Black SWA. Been looking but cant find a white 'outdoor' cable. Cant use T&E as conduit/trunk not tidy enough.
Hi salisbury spark
The only cable for outside use in white I can think of is MICC (pyro). Rarely used for submains these days though. CSA range from 1.0 - 240 mm². If all else fails paint the SWA we used to use a company called undetectables who paint cables ect to blend in with the building was expensive...
Regards
Reply to what outdoor alternatives to SWA... in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
It's galvanised and provided you coat any cut edges with galv spray there should be no signs of undue corrosion any time soon. Galv trunking...
nicebutdim
N
Generally it would depend on the circumstances whether the armour is earthed both ends or not, and not just dependent on whether it's 2 or 3 core...
