What power factor to use for motor? | on ElectriciansForums
Discuss What power factor to use for motor? in the Commercial Electrical Advice area at ElectriciansForums.net
UK
Wondering what power factor to use when working out design current of an old 25hp motor.
Nothing on its plate.
It's been wired in with a 32D MCB, on 4mm three core SWA XLPE.
Thanks.
Reply to What power factor to use for motor? in the Commercial Electrical Advice area at ElectriciansForums.net
Yeah when we start up the cone crusher the power factor can drop from .9 to .5. I’ve seen it drop down to .4 during start up. We have more than...
Do you have a test meter of any kind? if so, disconnect all four wires that go into the motor and check for a low resistance between them. You...
