What qualifications does the electrician need? | on ElectriciansForums
Discuss What qualifications does the electrician need? in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
E
Enzzo
Basically I've got a solar contract lined up, I'm the roofer but I'm currently searching for a electrician, I'm just wondering what qualifications he needs to be able to sign off the pv work, I'm sure he has to be NECIEC registered plus has to have completed a solar pv course, But I'm not 100% sure! The company who I'm getting the contract off is MCS registered so that's one less worry, any info would be greatly epretiated, cheers
It has to be commissioned by an MCS installer
a what now?
As things stand, the company is MCS certified, not the individual installer. It's then up to the company to ensure the installer is sufficiently competent.
This is probably changing to some extent in the near future, with the proposed new MCS requirements, but is how it works now unfortunately. So in this case the onus is on the MCS company to ensure that the electrician who's signing off the work is competent to do so, which in my view should mean both the paper qualifications, and relevant experience, but some companies seem happy with just the paper qualifications, or not even them... hence some of the rubbish installs some people get lumbered with.
The electrician will probably have to be a member of a CPS, such as the NICEIC, to notify the domestic installation side (if applicable), and they will have to be registered on the MCS scheme for the PV side.
NICEIC and MCS register companies, not individuals so make sure you hire a sparky in the company capacity, and not a guy doing some private work - unless he is privately registered.
With regards to the training there are some 'domestic installers' who have achieved a PV qualification - so you may find a company doing PV work, but they are not electricians.
The EAS has enforced that PV training providers now only enrol learners with an NVQ 3 as minimum entry - this is being challenged by many and so is in limbo at the moment.
like i said MCS installer
the company that's subbing the work out is MCS certified, so the actual electrician working as a subby wouldn't actually need to be actually MCS certified themselves, nor would the company they worked for.
When we first started up we subbed in an electrician to work with us who wasn't MCS certified himself, but we were as a company.
so why don't they install the system ???
NICEIC are not the only company that registers electricians, much as NICEIC would like it to be so!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
sorry, but I get a bit annoyed about this.
If you are MCS registered (which as the employing company you should be), then your electrician does not need to be MCS certified. He needs to be registered with part P so he can certify the AC side. This could be NICEIC, NAPPIT or ELECSA. He should also be competent to install the DC side and the usual way to demonstrate this is to have a solar PV qualification such as C&G, but there is no specific requirement or standard on this.
How else do you think the double glazing companies and chancers managed to get in on this!! (not suggesting that all companies who don't have an electrician employed by them fall into this category!)
If you are not MCS registered your best bet is to approach an MCS registered company with a view to them doing the whole job and you getting an introduction fee, and labour if your going to work on the install.
I'm registered with Nic for electrical works and Napit for mcs I would rather keep it this way if I change which I may do in march I will drop the Nic like a brick
to the op the last roofer we all know off went bust recently stick to roofing
Reply to What qualifications does the electrician need? in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
This isn't at all unusual. Companies often use subbies and as such are just essentially paying for their services resulting in little or no...
Best Electrical Courses I endeavour to create a "best electrical courses" thread for 2025 (so training courses that did well during 2024 are the...
