what rcd amp size? | on ElectriciansForums
Discuss what rcd amp size? in the UK Electrical Forum area at ElectriciansForums.net
North
hi,
what RCD amp size to power an outbuilding that has 4 x 2 gang switches, 2 x 1800mm twin florensent lighting, 3 x outdoor flood lights, 1 x multi-gang single pole switch
also im guessing it would be best to have another distrubution board out in the outbuilding?
thanks you for any help that is given
Do you do any of your own homework? How do you expect to learn anything of you just ask on here without knowing what you are being told?
hello, i take on board what you saying and appreciate it. but im on a home study course and the material isnt that great, so im actually learning more asking these questions then understanding were the answer came from and working backwards.
They is no point as you say to just getting the answers, so i do make sure i fully understand it. The course material is far too technical and just jumps straight in like im already a qualified electrician were as on here you get real answers from real people.
hope you can understand were i am coming from. This forum so far has been fantastic help to me.
suggest you search the forum for threads regarding supplies to garages/outbuildings etc. there are loads of posts with plans for cable sizes, protection devices etc.
as for you RCD, you would generally fit this in the garage if using SWA and the amp rating would be larger than the design current.
There is no simple answer to what your asking.
Will the sub main be SWA?, if so that can be protected by an MCB. Then in the outbuilding, a new distribution board will be fine, although without knowing what type of wiring systems your using, they will need to be protected by a 30ma RCD.
Again, the size of the MCB depends on load and cable size. Which you will need to do your calcs for.
Then the whole earthing arrangments comes in, is it PME? Is it a suitable' building to export PME into etc..
I understand that you are trying to learn on here, there is no such thing as a daft question is what I was taught at college. But surely looking back at some of your other threads, maybe this course is a little advanced for yourself. I don't mean that in a derogatory way, is there not a level of course beneath what you are doing to help you understand a little more about what you are needing to know?
It is one thing to learn some of the theory on a home-study course, but what are you actually planning to do with it afterwards? Are you joining an apprenticeship scheme for the practical experience or just planning to do a few courses at home then go out as an electrician?
no no. i get pratical sessions in house also which are to come later on which will fit alot more pieces together. then after all that it will be out in the work place as a mate and to gather evidance towards my qual.
i would dream of doing a bit of theory then starting as an electrician. lol
Sorry to repeat myself, but do you know the difference between MCBs and RCDs and the functions they perform? Your thread starts off saying RCD, then says MCD, and I suspect it should perhaps be MCB?
The only reason I'm asking is that I can't see the point in worrying about sub-boards and whatever if you don't know this. Daz
Reply to what rcd amp size? in the UK Electrical Forum area at ElectriciansForums.net
