What Reason for RCD Working on 0degrees, not 180degrees? | on ElectriciansForums
Discuss What Reason for RCD Working on 0degrees, not 180degrees? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
acvc
Ulan Bator, Ulaanbaatar, Mongolia, Mongolia
Tested an RCD today, 30mA.
15mA time : >1999ms
30mA : 44.1ms on 0degrees / 53.8 on 180degrees
150mA : 15.8 on 0degrees / >40ms on 180degrees.
I did this four times, similar results each time. Zs at that socket 0.91ohms.
I don't understand why an RCD would trip on one angle of the phase and not the other.
Can anyone fill me in? :confused:
Thanks in advance
A mate had the same problem on a Volex RCD, using his Fluke testers which had just been calibrated, tried it with my megger, no problem. Took the flukes back to Neweys, they sent them off and the testers were faulty...and they had been fine before they were calibrated.
Reply to What Reason for RCD Working on 0degrees, not 180degrees? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
