Thank you mate.
do you have any idea about the second assessment? Should I show them any job I have done or is there a specific job that they will need to see?
No worries mate, I’ll try and make more sense this morning...
They’ll want to see the following documents-
Proof of qualifications
PL & PI insurance
In date calibration certs for MFT
Safe isolation kit
H&S Policy
Complaints log
Work diary
Quotes & Invoices
Copy of BS7671, GN3, On Site Guide, etc...
All the various parts of building regs that are on list they send you. I printed them off and keep everything in big ring folders.
You’ll need a printed copy of an EIC for the job you’re showing him/her.
You’ll also need some EICR’s to show if you’re carrying out them and want to be part of the EIS.
Job wise, you’ll need 2 circuits that have been recently installed, may allow a CU change? Best to phone and check with them, they’re normally really helpful.
you’ll get given a sheet with 5 questions on about the regs. Don’t worry they’re easy and can use your books for reference.
you’ll get asked to carry out safe isolation and prove dead and then do some testing.
Normally along the lines of a Ze test, R1R2 of the circuit you’ve installed, IR, Live Polarity, Zs, RCD
While you’re carrying out the tests, they’ll ask you a few questions on why you do them, what readings you expect to get etc...
As long as you’re confident and know what you’re doing, you’ll be fine so try not to worry about it.
Don’t forget to offer them a brew, and remember, as long as your cheque clears, you’re in.
Nearly forgot, you’ll need Risk Assessments for the sites you take them too; and you’ll need to email the assessor a COVID-19 risk assessment prior to your site visits.
Good luck ???
