G
gpz900jim
Situation: You have just finished doing some electrical work that requires a EIC. You complete all tests ok, but when you test the RCD, It fails. You tell the customer that there is a problem with the RCD, and it needs replacing. Question; If the customer will not pay for a new rcd, what should you do? You cant issue the certificate, and your work does not comply without the rcd working ? If someone used your non certified circuit (obviously without your permission) what would the legal situation be ?
By the way, this has/is not happening to me, its just a scenario I dreamed up today when I was testing an rcd
