P
pirhead
Just checking the regs for size of circuit breaker or rcbo to protect pv. the regs only says Type B as far as I can see:shades_smile:
Discuss What size circuit breaker or rcbo in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Just had a look through the paper work nothing immediately apparent it does say on the side of the invertor which is a Stecca 500, 5 Amp Max does that mean I can use 6 Amp RCBO:bow:
Thanks it is a 540w system on 230 volt supply. comes out at 2.34 AmpsIsn't the size of the protection device governed by the load design of the installation.
Reply to What size circuit breaker or rcbo in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
