M
magpiemorgans
I am installing a 7.5kva transformer 240v / 110v single phase .
The primary side of the transformer is fed from a 32A type D mcb and wired in 3 core 10mm swa from a board next to the transformer .
The secondary side is wired in 10mm 3 core swa and feeds a 12 way enclosure next to the transformer.
There is one circuit in the enclosure at present , a radial feeding a 110v 16A commando socket which is protected by a 16A DP mcb and is about 5 meters from the enclosure .
My question is what size mcb should I install in the enclosure as a main switch ?
I was thinking of maybe a 125A DP mcb or a 63A DP RCCB ?
could anybody offer any advice please .
