What SPD on flat conversion | on ElectriciansForums
Discuss What SPD on flat conversion in the UK Electrical Forum area at ElectriciansForums.net
Princes Risborough
Hi everyone,
Got a job converting commercial property into 4 flats, 2 up 2 down all with electric meters on the outside on ground floor, SWA to each flats consumer unit,
Question is will have SPD in consumer unit, do i need SPD in isolator at meter end?
Hills23
Reply to What SPD on flat conversion in the UK Electrical Forum area at ElectriciansForums.net
This can be done. First you need a new MPAN number for the other meter. You will need to split the supply and feed SWA to upstairs coming off a...
Yes the first bit is just standard wiring, TNS lead cable into cut-out, cut-out to meter, meter to DP isolator, top of isolator is sealed as per...
