What speaker cable do I need to connect up these speakers? | on ElectriciansForums
Discuss What speaker cable do I need to connect up these speakers? in the UK Electrical Forum area at ElectriciansForums.net
HappyHippyDad
Supporter
Gloucestershire
I have just removed a rather expensive CD system from a house. I did explain to the customer that I thought it was worth quite a bit, but they just wanted shot of it.
Unfortunately no working speaker cables as I had to chop them off.
The unit is the bang Olufsen 9000, 6 CD player
[ElectriciansForums.net] What speaker cable do I need to connect up these speakers?
The speakers are Bang Olufsen beolab 4000 speakers. I believe one of them is mark1 and the other 2 speakers are mark2. They both have the 8pin round connectors in them for the speakers.
Do I just buy 8 pin Bang olufsen speaker cable? There seems to be 2 different types but they look identical.
First one = Powerlink mk 2 compatible - Black (8 pin DIN cable with fully wired 8 cores) - https://soundsheavenly.com/powerlink-8-pin-din-connection/23-powerlink-mk-2-compatible-black-8-pin-din-cable-with-fully-wired-8-cores.html
Second one = Powerlink mk 3 compatible (8 pin DIN) cable with 4 cores wired, low profile cable - https://soundsheavenly.com/powerlink-8-pin-din-connection/20-266-powerlink-mk-3-compatible-8-pin-din-cable-with-4-cores-wired-low-profile-cable.html#/1-length-05m
Will either of the above 2 cables work?
Easy one !! The speakers are Active so yeas you will need 8pin cables . Dont go down a Rabbit hole on quality etc etc .We are NOT talking high end hifi at all .Not bad Hifi ... but not worth spending a fortune on cables
Thanks Luke.
There seems to be 2 types of 8 pin. See both my links. I'm not too sure if one is correct and one isn't, or if they both would be fine.
May I suggest that whatever cable you buy, avoid the uni-directional copper ones!
Also, you probably don't need to use this for your internal fuse
if you've cut the cables... can you count the cores?
I see the links show "fully 8 cores wired" or "4 cores wired",,,, so whatever cable is was??
That's a good idea!
But... I've now taken them out from where they were and there were 2 different types there as well!
1 x 8 pin went into a multi player port.
1 x 8 pin went in the CD player.
2 x 8 pins went into the speakers.
I've counted the cores.
In 2 of the cables there were 3 cores and in the other 2 there were 6 cores??
Its possible they both work .. as the main 4 cores will be cover signal and power .The 4 core might be for older (Like this ) models. I would just call them and ask .
Reply to What speaker cable do I need to connect up these speakers? in the UK Electrical Forum area at ElectriciansForums.net
