G
Grinnders
About to have a roof installation done for some SANYO HIT235SE PANELS and a SUNNYBOY inverter.
I want the inverter to be located next to the consumer unit in the integral garage. The gable end of my house is almost directly in line.
I had assumed the cable would run down the outside of the house and because of the length of the run (2 stories) know I need a higher spec cable than if the inverter was in the loft. What would you recommend?
The installer is suggesting 4mm and has made the assumption that the cable will run through floors on the inside of the house.
1. Is 4mm enough?
2. Is there a technical reason for running the DC cable inside the house rather than the outside?
Many thanks
1. Is 4mm enough?
Many thanks
