what supply is this? | on ElectriciansForums
Discuss what supply is this? in the Australia area at ElectriciansForums.net
seppe
only recently qulifide and came across this then pricing a job looks to me like a TN-C-S with the earths coming from cut out but was unsure due to 2 cables going in at the bottom.
  • [ElectriciansForums.net] what supply is this?
Its a TN-C-S (PME) System. the cutout have been changed to suit. It does state on your photo that its a PME but if you want to double check contact the supplier.
Depending on your planned work (i.e. if your thinking of a rewire) you may need to contact the supplier anyway to uprate the fuse?
TN-C-S Drawing Attached.
PS: Interesting to see the difference in the colour of the L & N meter tails!
bl@@dy hell, Nothing wrong with your eye sight :)
This is TN-C-S the 2 cables are one in and one out and the other does link to another property, this was common practice by the Electricity Boards to save running two cables to properties where the cutouts where in the same location i.e. back to back on adjoining walls. ( Ex Electricity Board sparky )
Reply to what supply is this? in the Australia area at ElectriciansForums.net
Thanks, guys for explaining why I get the strange readings without using three prongs. I want to say I tested with my TIS 849 as well, but I'm not...
Yes, for example: https://kingsmillindustries.com/product/km2-20-10-sc/ However, the reality is the L-N-E style are far more useful in general as...
