What tests do you do before CU upgrade? | on ElectriciansForums
Discuss What tests do you do before CU upgrade? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
E
eskimo39
Before upgrading a customers old rewirable CU to a modern RCD board, what tests do you do to minimise tripping problems with the new board?
A Ze, ring final continuity and a blanket IR....L&N-E.
Also a visual on some accessories particularly hallway and landing switches to check for shared neutrals, earthing and bonding etc. Depending on the results of the "snapshot" of the install, advise the customer accordingly.
just wondering
the blanket IR test - that's L&N(linked)- E?
is this the safest way to IR with appliances in circuit -for a quick 'snaphot'
Reply to What tests do you do before CU upgrade? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Ah my mistake - apologies. I have something more or less like this wylex unit and the flappy plastic cover has got a broken pin so won't stay one...
If it’s rcbo’s, then it’s 30mA per circuit… an rcd mainswitch is 30mA for ALL circuits It may just be a cumulative earth leakage which was just...
