what tests to do?lv panel | on ElectriciansForums
Discuss what tests to do?lv panel in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
B
bredon86
i am testing a lv panel in a factory which has 20 ways feeding all each isolator for each piece of machinery. is it possible to still do a full test or can you not test live. therefore not gather a zs reading?
cheers
theres an isolator with 3 phase sockets underneath then to the machine? so take the zs at the sockets????
Spot on, if there was no socket then you would normally get a Zs at the isolator and do an R2 continuity check between machine and isolator just to prove cpc continuity.
Reply to what tests to do?lv panel in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
In the 80's I was taught that with PME earthing arrangements we used 16mm for the main earthing conductor, some went a bit crazy and were bonding...
Hello Ric2013, MJPD29 and westward 10. I have a multimeter that I tested the voltage with and before I open the socket up I use a plug in tester...
