What to put on EIC | on ElectriciansForums
Discuss What to put on EIC in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Amp David
Mentor
Glossop
When a shower circuit is run in SWA into the loftspace then its run in t+e to the isolator and onto the shower, what size conductor would you put down on the cert?
Got one to do and must admit I don't have clue about it:rolleyes::confused:
i would put the twin and earth size , as the cpc would be smaller ,and note on the cert and CDU that the cable changes , im asuming the swa would be 3 core so all cores are the same size , would also use 10 mm could ask why SWA
Yes, you can even enter F/A or G/A in the wiring box to show that you are aware of the different wiring types.
Runs up the side of the house as they aren't prepared to lift any floors
Reply to What to put on EIC in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
https://professional-electrician.com/technical/replacing-a-consumer-unit-in-a-dwelling-niceic/ All circuits should be tested
There are two reasons for a fuse/mcb they are: 1) fault conditions - which must exist always, and be capable of operating for all points on the...
