What to test + form for new circuit.. | on ElectriciansForums
Discuss What to test + form for new circuit.. in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
T
tomchester999
Hello
If I am adding a new circuit then i would need a full electrical install cert. What tests would i be expected to carry out? just this new circuit or the whole installation?
thanks
Tom
you must test your new circuit, obviously. there is no requirement to test circuits you have not worked on, but it would be good practice to test the whole installation if only to cover yourself should an incipient fault be present. it all boils down to whethe ror not the client will pay for this. a least, check and test the main earthing and bonding.
Reply to What to test + form for new circuit.. in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Thank you all, yes I didn’t think they do and I have done minor works but the helpline was not very helpful. Got my yearly assessment soon so I...
Unless the circuit is new or has recently been tested/certified by a.n.other, I'm not sure how you prove the circuit is 'safe' to connect to...
