what type of 10AX 1 way switch is this- can I get replacement | on ElectriciansForums
Discuss what type of 10AX 1 way switch is this- can I get replacement in the Lighting Forum area at ElectriciansForums.net
sam_123
ireland
[ElectriciansForums.net] what type of 10AX 1 way switch is this- can I get replacement
TL;DR
where can I get replacement part for 10ax 250v 1 way switch part of this as switch is broken and all switches are like this? what is it called?
  • [ElectriciansForums.net] what type of 10AX 1 way switch is this- can I get replacement
Which part is broken?
Looks like a schneider GET range - their ultimete grid range.
Any electrical wholesaler etc should stock
?thanks my local electrical supplies store does not have this and will not order in. I'll check with GET/ Schneider and see if they can recomend similar looking as all of my light switches have the switches in thin metal mounting plates.
Don't know about in Ireland.
But
City electrical (cef)
TLC
Edwardes
Even ebay usually has them
EDIT
And Amazon, free delivery by Monday
Reply to what type of 10AX 1 way switch is this- can I get replacement in the Lighting Forum area at ElectriciansForums.net
brilliant thanks for your support. Lee
Can you do a sketch of the wires and their connections but @littlespark is probably correct.
