I'm preparing an electrical drawing to be submitted to my AWJ (Authority with Jurisdiction) which uses NEC 2014 and IRC 2018. (Important because NEC 2018 changed some requirements). My system is 36 panels producing 12.9kW Dc, and 2 Growatt 5000MTLP-US 5kW inverters, with integral Dc disconnects mounted within 10ft of the array to satisfy NEC2014. They produce 21A max continuous output at 240vac 1phase each, with an internal 26A overload protection device. My First question regards the AC disconnect: What's the requirements of it?
I would like to use a 30A non-fusible 2 pole disconnect on each, specifically the Square D QO200TRNM, spec sheet attached, because its small and inexpensive. But I'm not sure if it has to be pad lockable in the off position, or if it has to be fusible?
