What type of bulb is this? | on ElectriciansForums
Discuss What type of bulb is this? in the Lighting Forum area at ElectriciansForums.net
uk
I have this bulb that needs replacing. Markings on it are: 2817, 240V 150W, C2b8, Germany. What type is this please? Also, can I replace it with 150W LED equivalent?
  • [ElectriciansForums.net] What type of bulb is this?
Is that from a high bay warehouse light?
Looks like a standard edison screw.
Direct replacement with LED however they are far more energy efficient than fillament type lamps. So 5 - 7 watt would be a good replacement.
I originally thought that but the shape of it is getting me thinking maybe it’s a metal haylide or similar.
I at first thought that, however I'm finding it difficult to judge the size of it. Going off the wood grain and the fact there are is no symbol for internal or external igniter on it swayed me to thinking standard Ellison.
C2b8 is the lamp shape designation, but google isn't throwing up any results.
Just looks too small for an ignition type lamp, need something else as a size reference.
Ok, I have exactly that lamp, except the markings are:
2817
240V 150W
C168 this is the only difference and it may be that the OPs lamp is actually this one but the markings are not clear.
Overall length about 11.5cm, max diameter about 4.5cm, if that helps.
I have this in my Ikea uplighter, which is no longer available, nor is the glass shade which the removers broke, nor is the bulb/lamp.
It is a standard ES fitting, so any equivalent will be fine.
2817
240V 150W
It is C2b8 marking. You are right - got it on an uplighter from Ikea. Strange but my glass sed on it broke and I have a replacement shed different to before.
What confuses me is the 150W mark. Surely this cannot be Incandescent 150W in an uplighter? Hence the question on LED of 150W
2817
240V 150W
So what type of lamp is it? discharge, LED, halogen?
If it's an Ikea fitting and it 150 watts then it will almost certainly be incandescant or at least some type of filament like halogen.
In the interests of reducing the number of dead dolphins and assuming it's not running on a dimmer, replace it with a 15 watt LED lamp (bulb) that is a recognised make has a standard ES base and looks like it will generally fit.
I believe it is an incandescent lamp. It's the top, uplighter part, of a dual=purpose lamp, with a swivel, lower level reading lamp which is a 40W screw -in reflector. Yes, the top lamp is on a sliding dimmer.
Times change, eh?
Reply to What type of bulb is this? in the Lighting Forum area at ElectriciansForums.net
Hi, since USA and Japan have 110v - 120v supply, you might search for lamps intended for USA and Japan. There is a big probability that they work...
Hi all, got a customer with 3x 900mm straight double peg 110w bulbs/lamps. It seems led equivalents of the S14S and S14D type are available, but...
suffolkspark
