What Type of Cert | on ElectriciansForums
Discuss What Type of Cert in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Seanw
We have installed a new supply to a 3 phase heater in a commercial property . This consisted of a new 10mm armoured cable running from a existing board to a new isolator on the wall. My question is do we have to fill out a full blown electrical cert or can we use a minor circuit as it was only 1 cable installed . We cannot find the old certificate so there is nothing to go on . We use easycert for our certs so which one would i need to use ?
ok but if the board is 24way i would only issue for the 3 ways that i used ? ie 22,23,24 on the test sheet i would leave the others bare ?
Reply to What Type of Cert in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Do a minor works for connecting the new gas boiler and add some notes regarding the addition of the bonding.
much more information required. Is the supply to the first building a DNO supply or a sub main cable from another building ? if it is a sub main...
