What type of circuit breakers can I add to my panel? | on ElectriciansForums
Discuss What type of circuit breakers can I add to my panel? in the UK Electrical Forum area at ElectriciansForums.net
WEGL08
Atlanta, GA
Hi everyone - I appreciate your time/opinion on this:
I'm lucky enough to have a 200 amp electrical panel with a lot of open spots for new circuits/circuit breakers. I have an unfinished area in the basement that I'm wanting to make into my shop and it currently doesn't have any outlets. I wanted to run a couple 20 amp circuits in there for my power tools. I was going to simply buy the same exact type of circuit breakers currently in the box (the rest of the project I know how to do).
The house was built in 2000 and hte circuit breakers currently in the box are "Challenger" brand which are no longer made. I've been trying to figure out what type of circuit breaker I could safely put into one of the open slots on my electrical panel. Any expertise/help would be GREATLY appreciated.
Thanks!
  • [ElectriciansForums.net] What type of circuit breakers can I add to my panel?
Thanks!
Web look at that sticker inside the panel door and it should have replacement breakers wrote in there. Good luck
[automerge]1577717115[/automerge]
Thanks!
I’m pretty sure GE THQP breakers will fit
Reply to What type of circuit breakers can I add to my panel? in the UK Electrical Forum area at ElectriciansForums.net
There is nothing inherently wrong with this part of the layout. There is another option that you may want to consider. Those supply conductors...
Yes you will need to install # 4 wiring times 4 for your 2 hots, 1 neutral and 1 equipment ground. As for keeping the grounds and neutrals...
