What type of fuse & what rating is this? | on ElectriciansForums
Discuss What type of fuse & what rating is this? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Goody
London
Can someone tell me, by looking at the pictures, what type & what rating this fuse could be?
Should I open the box & see?
Cheers!
[ElectriciansForums.net] What type of fuse & what rating is this? [ElectriciansForums.net] What type of fuse & what rating is this? [ElectriciansForums.net] What type of fuse & what rating is this?
God knows whats in there, may even be old 3036's.
As Paul said if it's sealed I would go opening it up unless was absolutely necessary
Metesco was the old metropolitan electricity supply company.
Just put NV and that's it.
The DNO will not know, you cannot find it legally thus you cannot verify (NV-Not verified).
If the DNO are willing to come out and check then let you now fine.
Mind, if may have a fused N in which case the DNO are in heap big trouble end of!
i would say that a call to DNO is appropriate. ask for a service head upgrade. as paul has said, there is the possibility of a fused N. also 3036 fuse at 30A which is way underreated by todays standards
I think you will find there is a ceramic wire fuseholder last one I had seen gad a 2.5 copper cable across it and the guy I was helping was just going to put down 60 amp rated until I said better check as there is no seal anyway
Another thing to take into account due to age ASBESTOS ??? apart from the legals and safety aspects of porcilane fuse carriers
Call DNO and request upgrading as there is a funny smell coming from it :)
I will put "N/V" as you have advised but is it the general practice where you could not figure out the fuse type? Makes me feel like I am "shooting in the dark"
How come DNOs have to replace electric and gas meters every say 10 years but when they do there is a perfect oppertunity to report back on the main incomer and these types of head ends should be eradicated
There private companies now ...right!! What your suggesting will eat into the profits if they had to replace all the old obsolete service heads etc!! In today's world money as in profit, always seem to rule!!!
Since when have they replaced meters every 10 ten years??
Reply to What type of fuse & what rating is this? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
I can imagine it just disappearing (loudly) under short circuit conditions, then the resulting blast/plasma etc. casing the busbars to flash over...
The pics you put up of the consumer unit are all good .....all circuits RCBO protected and as above swap the fuse out for a 3 amp
