What valve is the flow plumbing advice | on ElectriciansForums
Discuss What valve is the flow plumbing advice in the Plumbers Forums area at ElectriciansForums.net
What valve is the flow Hi all
I removed a radiator off the wall and forgot to note what valve was the flow as I'll be replacing with a new radiator with a trv. Without putting back and re connecting how can I tell what pipe is the flow and what pipe is the return because I assume the trv goes on the flow. Btw both plastic caps are missing off the valves. Cheers in advance.
What valve is the flow to read more on the original thread at Plumbing Advice
See also UK Plumbing Advice for all UK plumbing advice needs.
Reply to What valve is the flow plumbing advice in the Plumbers Forums area at ElectriciansForums.net
Isolating valve Is it good practice what I'm planning to do. I want to drain the central heating and then put 2 isolating valves on the flow and...
dwalsh1
Z
Radiator valves question Hi guys, got supplied some corner valves but they have a rubber to go into the radiator inlet to create a seal. Well I...
Zach054
Z
