What work can i do?? | on ElectriciansForums
Discuss What work can i do?? in the UK Electrical Forum area at ElectriciansForums.net
J
jakesm20
hi, im an electrician and i finished my 2330 just before the course changed. I am now unsure to what im physically allowed to do on my own.
I don't have my NVQ yet due to constant dodgy jobs such as un-qualified employers, being horribly under paid and just generally being mistreated. ive been through 4 employers in 3 and a half years and am now felling like i will never find employment with a bit of security and where the employer is at least a bit respectful to how hard i work.
The good thing about working with so many people is Ive worked in many different environments so have learnt a lot. i feel confident to do basic full house re-wires alone and have done ( For ÂŁ20 a DAY! ) including test and inspection. iv'e also gained other bits of knowledge in more specialized areas
I'm now thinking why not do small works on my own through small advertisements? the problem is, am i allowed? i don't want to be a another cowboy. iv'e worked with far to many as it is ; )
Many thanks
dont need to do anything before the 2382 apart from read up on your regs. scam=scheme membership lol
as for work it`s whatever you are "Competent" to do that your allowed to do
so let me just go through this;
the level im at now is iv'e completed my 2330 and have no NVQ or AM2.
If i get my 2382 and join a scheme i can work independently only on a domestic scale
including test and inspection with my signature on the test sheets?
egggsakkly. the scams ( and elecsa is, IMO, the friendliest to us) require competence in installing and testing, also th 2382 ( 17 edition qual ) to join.
Thank you all so much, this is one of the most helpful and responsive forums i've ever been on.
if theres any other information regarding this subject i should take into consideration please let me know, thanks
Contact the scheme of your choice for more info on what they need from you.
Will usually consist of evidence of your work to show them, demonstrate your skill and safety in installation and testing, posessing the correct documents test equipment and insurance, and having a back pocket full of folding stuff to hand over.
Well being unemployed is just a status, and not a problem when registering is concerned.
If you haven't got a set amount of work done to show a scheme, then IMO best to go with ELECSA. They will want 2 jobs to see, one classed as a major and another a minor ...............a major more often than not is a CU change, a minor will be almost anything really, say installing an outside light or a socket in the garage.
You can do both of these in your own house, or a relatives house as you want
Reply to What work can i do?? in the UK Electrical Forum area at ElectriciansForums.net
It applies to commercial if it shares the same supply as a dwelling.
It's actually not as those are accidents outside of work, if you suffer an injury whilst working for someone else or doing private work then...
davesparks
