domestic spark
basically this shows out house, a lean to connects outhouse to house. spur from ring in loft out to JB. IN 2.5mm t&e.
carries on in 2.5mm to feed D/SO for FRIDGE.
another JB by D/SO down sized to 1.5mm t&e goes to switch then feed from switch for x1 light.
FROM JB also feed taken for light outside and one switch. fed off in 1.5mm t&e clipped to outside of house for light outside.
hope this is clear.
THIS is wrong as 1.5mm cable is now on a 32a MCB and is only rated to 15a approx
only way to achieve this would be to fuse down by adding FCU. 3a fuse.
t&e clipped outside. cannot withstand outside demands, heating up freezing cold, effects cable dramaticaly.
no means of mechanical protection for environment etc.
and i could go on.
codes you would give if coming across this and why. thanks in advance, and also what you think. nice easy one
