What would you do - inaccessible JB | on ElectriciansForums
Discuss What would you do - inaccessible JB in the UK Electrical Forum area at ElectriciansForums.net
Midwest
Nearly Esteemed
Oxfordshire
Doing a kitchen refurb, adding new RFC etc. After stripping out all the old stuff, I'm left with a JB which will be inaccessible, which had been used to feed a spur form the existing house RFC. The spur leg has been removed, but still leaves the JB. Whoever did the JB, didn't cut the conductors, just removed the sheathing & insulation to do the joint.
Once the ceiling goes back up, this JB will be inaccessible. To replace this JB with an MF JB, will require some rewiring & damage to decoration to the room above, as the cables to JB will be too short.
What would you do, replace or leave as is?
Is this connection on the circuit you are changing?
Nope. This RFC is the only one currently in the house, and its being removed from the kitchen. There is another socket on this RFC, which will need to be removed from the kitchen, can't rewire the legs, 'cos of floor coverings above, so the ends of the legs for this bit will go in a MF joint.
Just this one, need to decide what to do?
It's a bit b like this shiny new CU;
[ElectriciansForums.net] What would you do - inaccessible JB
What would you do about the tails and main earth on this? On an EICR it's probably a C2
Probably bring it to the attention of the owner, explain it's not right but unlikely to cause any problems, and if they want it altering then sort it out.
If other issues were apparent then I might worry more.
I'd be a bit more worried about that 'Important Safety Notice' below the CU. I have one of those, and it wasn't until about 5 years later, that I found out what the ---- had done to my chimney pot;
I'd be a bit more worried about that 'Important Safety Notice' below the CU. I have one of those, and it wasn't until about 5 years later, that I found out what the **** had done to my chimney pot;
Haha thats a right lash up if ever I saw one! Why is the pot so low down? I reckon you commissioned that on purpose with a sign that said "f*** off Father Xmas" on it.
I would like to see the tails glanded and clipped. It looks like they are hanging loosely out of 20mm grommets and so will be pulling on the board isolator (?).
Reply to What would you do - inaccessible JB in the UK Electrical Forum area at ElectriciansForums.net
Most manufacturers recommend them to be fitted. We are required to take that into account. If they had been fitted clearly it would have been...
Yes the first bit is just standard wiring, TNS lead cable into cut-out, cut-out to meter, meter to DP isolator, top of isolator is sealed as per...
