what would you do? | on ElectriciansForums
Discuss what would you do? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Monkeyhanger Land
Went to an install today...old wylex 3036 fuses. Boiler on 16A fuse, checked Zs...14.48 ohms. Regs say max 5.75 (I think)...check supply cut off and find its a PME system.
What would you do?
It was to wire a central heating boiler...wiring was 40 year old, early pvc. Turned out it was a supply issue...earth was just pushed in to the cut-out and not connected to anything...hasnt been since year blot.
Reply to what would you do? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
For what OCD? There may be other means of over current protection that allow a Zs of0.45 (HRC Fuse?)
With what looks like only 5 circuits you can probably put a little 5 way garage consumer unit in there if money is tight
