- Joined
- Jul 20, 2011
- Messages
- 90
- Reaction score
- 1
Hi there.
just fitted an external floodlight and the feed comes from the lighting circuit in the loft.
already a external 400W flood fitted around the corner to the one I was fitting.
Used artic cable 1.5mm (why does it have to be blue or yellow, awful colours to have on the outside of the house).
orignal feed to floodlight already fitted came from old junction box in the lighting circuit. Replaced this feed via dp switch(isolation) to new junction box that feeds both floodlights.
house has Old wiring, junction boxes all round. earth cable stripped back and twisted toghether with no sleeving outside the junction boxes. feed from one JB to the next was twin with an thin separate wire providing the earth. the jb I needed to use had the cover missing and had insualtion just sitting on it.
I replaced the junction box with a new one and used 20A terminal strip inside junction box for extra connections and the earths with sleeving. Replaced the old twin cable and seperate earth with new twin&earth with again 20A terminal strip for the earths outside the junction box.
tests check out fine.
obviously the rest of the house would be like this and I know it was the practice of the time.
my question is have I done enough for my little part of the circuit. or do i have to sort out the earths correctly with sleeving and possibly inside a junction box and do i have to then fix all the junction boxes in the loft area.
any advice would be appreciated.
many thanks
Spikenaylor
many thanks
Spikenaylor
