What would you put on report? | on ElectriciansForums
Discuss What would you put on report? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Doomed
Dorset
Testing a premises and all the older installation has its earthing only through the metal conduit / trunking.
I get good results on both the r1+r2 and the Zs results, but as there is no actual CPC what do I put on the report?
Thanks for your advice.
Just note the conduit is used as the circuit protective conductor on the cert not alot else you can do , as long as the conduit is in a good condition and not broken , it only becomes a problem if its added to or altered especially if its done in plastic
I'm hoping that you just mean how do you show the trunking or conduit as a CPC on your schedule rather than not knowing if it complies or not.
Just enter 'Trun' or 'Con' in the CPC box on the schedule of test results.
AMTEK ahen you put cable sizes on the CPC it has ARM,CON,Trunk,MICC and then a popup with sizes in mm for what ever size you put in
Reply to What would you put on report? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
The actual listed observations seem easily resolvable, comfortably less than a day's work. The picture of the supply poses a few questions...
As previously posted, almost certainly due to differences in readings obtsined with high and low current measurements on the meter, low current...
OLDBOY
O
