naylorpd
I've been wanting to control my lights by internet for a while, so unscrewed the light switch to see how deep the box was and, I thought, to confirm there was no neutral.
But to my surprise there were three T&E cables and the three neutrals were all connected together.
Two lives went to one side of the switch and one to the other. It's a one-way switch and one central light fitting.
But why three cables? One must be the incoming live & neutral, another the switched live & neutral to the light fitting. But the third? The next-nearest light switch is in the same wall but at least 3m away and is a complex 3-way switch arrangement - but I suppose the live feed to that has to come from somewhere...
Meantime, the backbox is only 30mm so will be a struggle to get a device in there with all the cable as well...not sure if I can change that as it looks like it may be screwed into a batten in the plasterboard wall.
