Whats PSC stand for and what is it? | on ElectriciansForums
Discuss Whats PSC stand for and what is it? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
If your doing installs and testing them you would be wise to brush up in this area, as Lenny said it's PSSC, along side which you also measure the PEFC, Prospective Earth fault Current the highest of these recorded values is the PFC which is entered on the EIC expressed as kA
LOL! Or as 30mA as I saw on one form handed to us recently!
Here's two pages giving further info:
Wikipedia
Posts on this forum about PSCC Calculation
sorry steve your right i should have been a bit more concise in my post
Cheers for all your answers-
so I have now established that:
PSCC = prospective short circuit current (L-N fault single phase L-L three phase)
PEFC = prospective earth fault current (L-E fault)
PFC = prospective fault current is the higher value obtained of the other two
What are the formulas for calculating these?
Why do we need to know what the PSCC and PEFC?
Thanks- John
Thanks- John
You don't need to know them on an individual basis you need to measure both to obtain the highest reading= PFC. You need to know it to make sure the protective device(s) in an installation are capable of breaking the maximum fault current that may flow in a dead short scenario, there is a max for a 230v single phase installation the figure eludes me at the moment, someone will chirp up with it shortly I expect
Reply to Whats PSC stand for and what is it? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
It is a pass or fail (as far as I recall) but you can resit it.
Hi I've nearly completed the 2357 NVQ. I'm just a bit stuck with Permits to work, Planned program of work and method statements. I work in the...
