What’s the chances me getting a 40amp cooker on this? | on ElectriciansForums
Discuss What’s the chances me getting a 40amp cooker on this? in the UK Electrical Forum area at ElectriciansForums.net
Justyjust
London
I recently purchased a property not looking under the the stairs at the electrics, now I’ve had chance and thinking about getting a new board installed and fitting a 40amp electric cooker.
I’m in doubts and unsure if it needs an upgraded cut out, the meter has a 1995 date on it. Smart meter blokes out on Wednesday to fit a meter
What’s your thoughts could this have a 30amp under the hood? Will the DNO have to sort this out??
Thanks j
  • [ElectriciansForums.net] What’s the chances me getting a 40amp cooker on this?
MICC liable to be accidentally struck.
3 phase head… L1 for you, L2 for next door. L3 empty
If you’re getting a smart meter fired, get them to fit a service isolator as well, as it will mean changing the fuseboard in the future will be easier.
Hopefully the meter monkey doesn’t walk away because it’s not a newer standard fuse to pull.
They will be able to advise better when they call out, what is that second thinner cable coming our of the top of the cutout?
It’s an old 1900 Victorian house been split into to large flats, the lady upstairs has a new meter fitted and looks like them cables from my supplier spur off to hers. She has a 60a fuse though.
The main head in your cupboard was possibly the original when it was all one house, and has been altered.
Might find there is 100A fuses in the main head, or a fuse for yours and just a link in the other one, as she has her own fuse in her flat.
You can ask about the MICC, but it’ll have been there for decades now without damage.
The cable itself is very sturdy, fireproof and can take some rough treatment, but the inner cores in black, and the “pot” on the end should all be within an enclosure for protection.
Do you think I should buy a isolator and ask him to fit it? Does the isolator go before or after the meter?
If you are thinking of a new circuit for the cooker etc., each new circuit will have to be upgraded to modern regs. So a new box is pretty well inevitable. I find that nowadays as the manufacturers who make the devices we are increasingly forced to fit by regs, also make the items we are forced/corralled to fit means the cost of you upgrade can increase by a factor of 5 x. Meaning if you fit Surge Protection Device and Arc Fault Detection Device and RCBO the cost of each unit is currently around £150 ish so a 6 way unit will now cost around £1000 plus as opposed to a year or so ago 2-300. I say this as this really is a scam on the part of large corporations imho.
Anyway upgrade is the way to go. If you are living in flats depending on the size you may have to fit AFDD. It looks like your supply has an earth, which is good, as the whole system (earthing) looks in need of some upgrading as well. In theory you could run a cooker from it as there is probably a circuit already there for one. It would need testing as a matter of being safe before connecting though.
Is the fuse held in this part??? Cheers
Yes. there will be 3 fuses in there (or possibly a fuse and a link) but as James says... not for you (or us) to be poking about in.
In your other photo you see a number of holes along the top. 2 for L1, 2 for L2, 2 for L3 and 2 for Neutrals.
Thanks hopefully Wednesday the smart meter bloke will fit a new meter and not have any issues.
Reply to What’s the chances me getting a 40amp cooker on this? in the UK Electrical Forum area at ElectriciansForums.net
