Whats your thoughts on this? | on ElectriciansForums
Discuss Whats your thoughts on this? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Amp David
Mentor
Glossop
Situation is this,
Been asked to look at and quote for extending a cooker circuit and replace the old isolator/socket plate.
Thing is fuse box is in kitchen and cut out is in the lounge, about 18m away and fusebox supplied in 16mm twin and earth.
If i bring said cooker circuit upto scratch, rcd etc, am i responsible for the twin and earth supply to the fusebox?
question is. is the cpc in that 16mm T/E adequate? you must bring earthing and bonding up to standard.
no, it's not. you are responsible for doing your work to current regs. you don't have to bring the rest of the installation up to current regs with the exception of earthing and bonding, as said. you should however comment on it in " comments on existing installation"
Reply to Whats your thoughts on this? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Yes the first bit is just standard wiring, TNS lead cable into cut-out, cut-out to meter, meter to DP isolator, top of isolator is sealed as per...
When you say plus kettle, does this indicate you are needing 13A socket/s on the island and a hob supply? and then an oven supply on a tall...
