when can 25p Wham bar cost you £80? | on ElectriciansForums
Guest viewing is limited
Discuss when can 25p Wham bar cost you £80? in the Electricians Chat - Off Topic Chat area at ElectriciansForums.net
Dammit Lenny that was my idea too now I've got to come up with another one.
OK you were phoning and texting your girlfriend and your wife found the number on your phone bill. To cover the fact that you're having an affair you told her it was your local Wham Bar wholesaler who was expecting a delivery and you were so excited about it owing to needing your fix that you were on to them every few minutes hence an £80 phone bill to one number. To cure your addiction to the infernal things you're attending a support groupon Tuesday.
A tad more fanciful than Lenny's idea but none the less possible:)
Lenny, spot on! my mate tells me there is a facebook group decicated to idiots like me! I was in the garasge and thought, mmm not had one of them for years, 10 mins later, the filling I had 2 weeks ago pops out.. And the bloody things arent as 'zingy' as they used to be!
When you cant get the wrapper off and throw it in rage and it smashes your windscreen , you then have to pay the exceess to get it replaced...................................................... you can tell Lennys done that then
There was the Plain wham bar and the Zingy one when I was a lad. Oh and the small ones that were 2p that sometimes had the little "Free Wham Bar" ticket inside!
only if the dentist is part teeth approved? (groan)
Knowing my luck, he'll tell me it's a different tooth, and I'll just agree....
just don`t let him do the root canal, not only expensive but take ages too :D I put wham bars in the back pocket for a couple of minutes softens them right up
You shouldnt have to pay for the dentist if "you need replacement work or a replacement of certain types of restoration within a year of the original work being done. You should return to the same provider of NHS dentistry."
Doesn't the same apply for private dentists?
Reply to when can 25p Wham bar cost you £80? in the Electricians Chat - Off Topic Chat area at ElectriciansForums.net
The second photo is partly obscured, but enough to see this is a typical Volex board, where the RCD circuits are on the RH side, and the bus bar...
That is most interesting. I've sat transfixed and watched the same (scaled-up!) process being used to join two sections of rail-head together...
Recommended Sponsor News
Hi everyone,
