When can an RCD be omitted from a domestic cable run | on ElectriciansForums
Discuss When can an RCD be omitted from a domestic cable run in the Domestic Electrician Forum area at ElectriciansForums.net
At any time.
There is currently no requirement to provide RCD protection for cables, other than those that make up a circuit for a location containing a bath or shower.
What about cables concealed below surfaces less than 50mm?
There is no requirement for them to be provided with RCD protection.
They do need an Additional protection Unless adequately protected from penetration from nails/screws or the like cables also require additional protection when ran in a wall containing metal parts i.e a stud partition wall with metal framework
If not protected by earthed metal sheath trunking or conduit at less than 50mm RCD required then
Earthed metallic sheath, earthed trunking or conduit, mechanically protected, be part of a SELV or PELV circuit or run in a prescribed route and provided with RCD protection.
Similar rules apply if if the wall’s internal construction includes metallic parts.
For those of you who think there is a requirement for RCD protection, you should learn to read.
It’s an option.
If you choose that option, it’s your choice, no one is twisting your arm forcing you to make that choice.
Oh and once again, I’ll point out that RCD protection is not an option for cables concealed above ceilings and below floors.
Reply to When can an RCD be omitted from a domestic cable run in the Domestic Electrician Forum area at ElectriciansForums.net
Hi All, In need of some advice on what is and isn't allowed under regs. I'm extending a circuit in my house so I can install a socket on the...
See there is the problem. I can put back to way it was. Is it safe, in my opinion NO!! It's wasn't safe before the incident. No Fused Spur...
