When do the PIR become obsolete? | on ElectriciansForums
Discuss When do the PIR become obsolete? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Could somebody please tell me when the PIR becomes obsolete and when we should be doing the new EICR test?
That is unless you are an NICEIC member. NICEIC can't supply the EICR pro-forma sheets to their members at the moment and have accepted the extended the use of the PIR until June 2012.
so can we use PIR forms?
Im going to be with NAPIT.
I bought a few Pads the other day fro the whole seller and PIR was one of these
I must say I find the NICEIC stance rather at odds with BS7671 as BS7671 says that the EICR will be in force from the 1st January 2012
I wonder if the NICEIC dead PIR sketch will catch on. I can see it now, irrate NICEIC member laments the demise of the Norwegian Blue PIR pro-forma sheets.:joker:
Yet again we have the NICEIC who are meant to be the "market leader" in this and have C@cked up big time and the previous post of I am still buying PIR pads at the wholesalers is the big con so when there is a problem you will be told you should have used a EICR as the PIR is no longer valid and the fact that nobody for some reason just will not print or sell the new certificate plus they will not comment on why (I mailed a couple and I am still waiting for a reply) I have said this before but it is worth repeating this type of thing makes us all look like fools and does nothing for the scheme providors and wholesalers credibility who were meant to manage this one day we might even get an answer as it is ok for us to say well I dont know whats going on but they cant get away with that line
In the middle of doing a big PIR/EICR (?) at the moment, got three big notepads that I'm scribbling in at the moment but been wondering what to do when it comes to writing it all up....think I'll ring the NIC in the morning! Great
Reply to When do the PIR become obsolete? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
As you've found out, there's capacitive coupling between cores which will induce a voltage into other cores when one (or more) is fed with AC. How...
I was a QS for 30 years with the NICEIC, basically you want to get a cabinet with all the test sheets from the guys who you are responsible for...
