Hi
Just a question here regarding testing and certification.
If you got called to a house to replace a socket that had its casing cracked or you put a lovely new B&Q chandelier up for someone would you then do a minor works Cert + Si + STR?
Seems a little overkill to me
If you don't what's the smallest job that you would do it on?
A MEIW cert is only one page and takes no more than 10-15minutes to fill in, providing everything is safe & sound.
Whats paperwork? is that the stuff the customer shoves in you hand, that serves as currency in the local:wink_smile:
lol, that's why its ****ing me off then, I was having to charge for my time to do all 3 and was just quoting too high
if its like for like I wouldn't bother with a cert unless its a rental property.
This job has enough paperwork without doing unnecessary MWC's too. The bloke down the pub won't even raise an invoice let alone a cert!
I agree with Murdoch, although its not politically correct etc, sometimes it is more practical. Although as a minimum i would do an EFLI test, even if i didnt document it.
Cheers..........Howard
Any addition I would do a MWC, anything requiring an EIC would get one, as said above for like for like replacements etc I wouldn't usually do a cert, I would do a test, however would just invoice and on my way.
Same here as Murdoch and Sirkit.....there's too much paperwork anyway...a form to change a socket?...no thanks.
Invoices done on iPad and usually emailed to customer then and there. Certs if EIC done on pc and posted. MWC I usually either do on pc and post or write out 2 copies
If your doing a lot of stuff requiring MWC you could do a small part of MWC on bottom of invoice, job sheet specialy if your doing L.A. or rental stuff get tenant to sign that you have been there and done it as well
You guys that do certs/invoices etc at the house, what do you do for your copy? carbon paper?
I do all my invoices at the end of the job on carbon paper. certificates I normally try and do if I can again on carbon paper (although I got told off by Elecsa because they were too faint so I now use handwriting blue copy paper, messy but not faint).
If I am doing a cert for an insurance company, etc. I normally fill it in on the PC at hoem and send it off.
anyone got a sample of there job sheets with the MWC incorporated would you send me a copy i would love to see the layout as this is the route i need to go
I like that idea. I hate wasting paper on all these certificates and this should also cause confusion with the customers filing; is it an invoice or certificate.
I like it, I have made up this rather quickly as an example of how to scrunch things up.
I always issue a certificate of one kind or another. Not only is it required (see earlier messages!) but I believe it sends out the message "this guy is qualified and knows what he's doing" (hey, you can fall most of the people most of the time :biggrin: ). My reason for doing that is the £35 job you got called in to do today could easily turn into a £500 job the next time the customer needs work doing, or when his neighbour/colleague/mate in the pub says "do you know a decent electrician?". Plain simple marketing!
As for how I do them ..... software, local copy for my records, backed up of course, and a PDF version to the customer by e-mail. If necessary, a printed copy by post, but that's quite rare now!
but that is the main question !!!!! do you know a decent electrician ????????????? in these parts its do you know a cheap electrician ?
I like the idea of a combined invoice/MEIWC , I might look at drafting one up myself based on my current invoices.
Personally I have started to get into the habit of documenting everything I do, which means a MEIWC for every job no matter how trivial.
This way if there were any future issues - worst case a fire started by faulty equipment- then I can prove I did the necessary checks when I was there.
I can also agree with eastanglian, it does look more professional to the client if you certify all works.
When do you actually do the paperwork?
robbo777,
durhamspark,
