When to use a RCBO? | on ElectriciansForums
Discuss When to use a RCBO? in the Australia area at ElectriciansForums.net
shakin2011
As far as i know an RCBO is basically a RCD+MCB. Now in what situations would I use such a device can you please tell me? I want to understand when to use it. Thx.
Also, if the price of the job allows then it is often better to use RBCO's as if there is a fault to earth then you only loose 1 circuit. With the normal split load boards then you would loose half the circuits, as usual it comes down to cost
I love them and have filled boards with them !
But then again i might use 3 -4 lighting circuits etc for a normal house . The more the merrier in my book
before 17th only ever fitted them in 3 phase DB's or if doing a single phase DB with only 1 or 2 RCD circuits. Personally now I only fit RCBO's even in single phase DB's, as most jobs seem to want every circuit individually protected. Suppose in a domestic situation though, where nuisance tripping doesn't result in 20 computers and half an offices lights going down, you can use the dual RCD setup.
Reply to When to use a RCBO? in the Australia area at ElectriciansForums.net
If they are standard RCBOs the MCB aspect could be b,c, or d , but the RCD aspect is almost certainly 30mA instantaneous. If the MCB aspect...
Duh!!! Just re-read Op's original post, it was converted to a RFC!
