BS7671 Amdt 1, 514.12.1 says:
A notice .... shall be fixed ... upon completion of the work carried out in accordance with Chapter 61 [initial verification] or 62 [periodic inspection and testing]. "Important, This installation should be periodically inspected and tested ... Date of last inspection, Recommended date of next inspection".
Clearly, if you've just done a full EICR or a whole new installation, then the label is required. But what about a modification or addition to the instalation? What about just a couple of new circuits in an extension? What about a new CU?
At my assessment for joining ELECSA, I changed the CU in my own house. I queried the point with the assessor, who said that in this case the label was required. If I had done a full EICR prior to the CU change, I would have agreed with him; as it is, I'm not so sure.
Do you apply the label but write on it the extent of the new/changed part of the installation?
