L
lamb
Went to wire up a combi this morning, first floor flat. So first of all I check the earthing and bonding.
Incoming DNO micc to insulated service head, BS951 clamp from copper sheath with no main earthing conductor installed to MET. Earth from CU just goes to MET, as does water bond. I have booked EDF to install a DNO earth clamp and braid or install PME, which they will do in their own time.
Both the landlord and the letting agents dont seem at all bothered, and do not intend to order a PIR of the property, saying they only legally need to provide a gas safety certificate. The rest of the installation is in a mess.
There should be a requirement for landlords electrical safety certificates, as there is for gas.
Rant over
Rant over
