where can I buy a tube of??? | on ElectriciansForums
Discuss where can I buy a tube of??? in the Electricians Chat - Off Topic Chat area at ElectriciansForums.net
the pict
Mentor
Brodick
I am going to renew the output shaft bearings on my Disco, I need a slide hammer which is not difficult but I need to make a "end" for it any one know where I can get steel tube threaded on the inside, not BSP or any weird stuff 22mm I think but I can confirm that later, I have made up ends before by welding a load of nuts together but to be honest they are not that reliable.
Pict
Pict
when I had a disco I found the LRO magazine was a very good source of help and info and I think they had an online forum too.
Prices for this sort of thing can go crazy e.g. Marine grade for over £200
Could you use a turnbuckle? (would be lh and rh thread) m22 under £20 on eBay.
m22 tap would set you back about £50 and you could make your own?
What length and material do you need? I could ask my toolmaker.
Any fabrication place worth their salt should be able to knock something up for a few quid.
You should look for 'connecting nuts', sometimes referred to as coupling nuts, which are just a long nut. If you can find them locally I'm guessing an M22 nut would be about 2-3 inches long standard. You might find a class 10 heat treated if you're lucky, unfortunately UK google searches from here throw up inconsistent results so maybe someone local can help you with a supplier..
LP, I have yet to size it up, this w/end if this weather holds up,
Strima, location is a factor here
Pict
My bad mate, should have checked your location.
I take it you have lots of local people around there? :lol:
Reply to where can I buy a tube of??? in the Electricians Chat - Off Topic Chat area at ElectriciansForums.net
Heh I know the brochures for courses with stock images of women using tools in random scenarios but when you're there it never happens, it's all...
Nice one! Thanks for letting us know.
Recommended Sponsor News
Hi everyone,
