tantle1961
I am wiring 2 outlets in the ceiling to control 2 plug-in florescent shop lights in my garage. The 3 ways are at each side of the garage at the 2 entry doors. The way I have it wired right now, both lights come on at either switch but turn off if either is unplugged. I would like both outlets to work individually if either light is unplugged. Also one of the lights is always dim if all bulbs are installed but they all work individually at another outlet. Not sure if this is related, but I ran out of 14ga wire and ran a small length of 12ga between the two outlets about 12 feet. Could this cause the flickering of the lights? I have installed 3 way switches with lights but not outlets.
This should be very simple if I can find a wiring diagram.
Thanks in advance for any advise.
Terry
Terry
