Where do you test from in phase rotation test on am2 | on ElectriciansForums
Discuss Where do you test from in phase rotation test on am2 in the UK Electrical Forum area at ElectriciansForums.net
Newcastle
About to re sit testing section of am2. Am I required to test phase rotation at the incoming switch and also the 3 phase socket and motor. Just can't seem to find any clear instructions on what they expect on this test
Not sure if this applies to AM2.
The phase sequence on the 3 phase installation would affect the rotation of the motor on the motor supply circuit
You will be required to select the appropriate Phase Sequence tester and perform a test at the Main Switch and at the motor connections.
Both tests should indicate the same phase sequence.
Thanks for the response really appreciate it, so that's kinda what I was thinking aswell for the test points and hoping someone would say the same. Ill be using the multifunctional megger tester they provide which has phase rotation onit
Reply to Where do you test from in phase rotation test on am2 in the UK Electrical Forum area at ElectriciansForums.net
That looks like a Metrel display (I have one), they have a permanent 3 wire display that measures the three combinations so I would say that’s a...
Having some issues with my companys fluke 1662/1663 tester. Zeroing 2 leads for continuity test we get the value 0.08 which is expected. The issue...
