Where to put socket for electric fire. | on ElectriciansForums
Discuss Where to put socket for electric fire. in the UK Electrical Forum area at ElectriciansForums.net
OL2
Hi, my friend is having a floating shelf with a electric fire, and I’m between minds where to put the socket,
I was gonna put the socket behind the fire which will be fed by a 13A fused spur but I’m having second thoughts about putting a socket behind there due to heat..
Would it be safe behind there, or would you suggest running the cable to the cupboards to the left or right? Thanks in advance
I’ve attached picture of something similar to what it’ll be
  • [ElectriciansForums.net] Where to put socket for electric fire.
I'd be inclined to set an unswitched socket to one side of fire (in boxed off area), controlled by accessible isolation switch somewhere convenient. Cables can be routed vertically in line with TV socket (which you've probably already done), then turned ninety degrees in line with hidden fireplace socket - keeps everything in zone.
Reply to Where to put socket for electric fire. in the UK Electrical Forum area at ElectriciansForums.net
There could also be a completely unsuitable junction box embedded within the wall and tiled over or just cables in choc blocks in old accessory...
