Where to read Ze..? | on ElectriciansForums
Discuss Where to read Ze..? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
sythai
Devon, United Kingdom
Another question please.... quite a few tonight?
Completing EIC certificate, domestic mains board is fed off submain supplied via switched fuse.
Just checking that I take my Ze at switched fuse ?
Thanks,
Sy
As Wirepuller , When you do the test make sure you test it with out the bonding to the services connected or you may get false readings
Again agree with Wirepuller. Youre right Sy , Disconnect Main Earth from the rest of the instation and
Test.That is your Ze.
The Test @ the C/U is the Zs of the Submain.
Isolate installation before disconnecting earthing conductor/bonding and reconnect earthing conductor/bonding before re-energising installation.
When testing Ze at a DB fed via sub-main, given that bonding conductors and final circuit cpc's are isolated from the test earth in order to avoid parallel paths affecting readings, should any other earths connected at origin of supply such as other sub-main circuits, bonding conductors, etc also be disconnected, leaving only a test to the main earthing point?
Not sure I follow.
Ze is external to the installation.
if its a sub main fed from another dist board it would be Zs and tested like another circuit , the Ze reading will be taken at the first point of the installation after the meters ,isolate the supply remove main earth and test between the L and N and the main earth block
Ze is between the incoming line conductor and the earthing conductor. Parallel paths removed by disconnecting main bonding or disconnecting the earthing conductor (usually easier).
The installation is isolated during this test.
Reply to Where to read Ze..? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
If the shared neutral is lost ,won`t you be getting 400v across both cottages? 2 phase US style but double the Voltage.
Adding a led strip isn't going to make much difference to the 3 phase balance. No real difference to where a 3 phase machine uses one phase to...
