Where to terminate a CPC in this fan. | on ElectriciansForums
Discuss Where to terminate a CPC in this fan. in the UK Electrical Forum area at ElectriciansForums.net
UK
I am fitting a timed bathroom fan into my bathroom.
As you can see from the picture below there are 3 terminals L N & S/F. No-where to terminate the CPC, there is also no room inside the enclosure for a chocolate block terminal or a Wago connector.
Any ideas?
[ElectriciansForums.net] Where to terminate a CPC in this fan.
you can just about make out the double insulated 'square inside a square' logo on the label.. meaning the is no need for a earth.. although like previously said.. just leave a nice long cpc, sleeve and block it and leave it tucked away incase they ever change the fan.
Reply to Where to terminate a CPC in this fan. in the UK Electrical Forum area at ElectriciansForums.net
I'm familiar with many domestic extractor fans which are primarily class 2 (double insulated) and consequently are not required to be earthed...
It is actually specified in BS7671 that the cpcs must be connected to all other sources of earth.
