which cable for volt free boiler thermostat. | on ElectriciansForums
Discuss which cable for volt free boiler thermostat. in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
J
jase31
Hi,
Ive been asked to connect a volt free thermostat to a combi boiler. The cable needs to either go from the boiler (under capping/plaster) upstairs, across the joists, and back down under capping/plaster in the hall, or may be behind the kitchen units, round the kitchen, and then through the wall into the hall.
What cable should I be using, I am thinking about 1mm flex. Should I use something else?
1mm t&e, 0.75 or 1mm flex. Your choice according to what you have to hand. Bear in mind it should be protected by a 3A fuse too (Gas Regs requirement).
How many cores does the device need? Just 2 or any more?
Are you chasing out for this job or is it all done before hand.
You can get a decent RF room stat for about 50 quid. Means you won't have to take up floors and chase walls to fit it.
Volt free is usually 2 core. If being plastered in I would choose twin and earth
Done beforehand, place is undergoing a full refurb so wired is as easy as rf.
If using t&e flat, then it should be changed to a flex for the boiler connection (enters via a gromit on the bottom and connects on a flip down panel), so flex all the way may be the best option. Only need 2 cores.
If you are talking about a standard room stat then you need to run a 3C&E not a T&E Yes a thermistat is a switch but it needs a neutral for the anticipator or accelerator resistor if you dont run a neutral then your heating system will 8-10% less efficiant because you will not have proper control.
Reply to which cable for volt free boiler thermostat. in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
This is an RSS feed of thread: Changing from system to combi boiler with under floor pipework. Content of the thread: Wondering should i change a...
All socket outlets up to and including 32A (which are commercial, not domestic) are required to be 30mA RCD protected. By the sounds of it you...
