Which certificate should I use | on ElectriciansForums
Discuss Which certificate should I use in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
J
johnny999
I have been asked to correct some code 1's on a few properties owned by the same company, the PIR's were carried out by another company, ( obviously checking on costs ) my question is what certificate should I use after the work is done , the faults range from mostly broken sockets & damaged ceiling roses with a few cpc missing from light circuits. The customer wants to be able to show that work has been carried out.
regards
If you will be working on more that one circuit it may just be easier to use a EIC and just note on the cert the wor carried out. If though you are only working on 1 or 2 I would just issue a couple of MWC's.
Reply to Which certificate should I use in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
With all due respect, if you're in a position, trained and skilled to be undertaking these works, you should really know this stuff. Especially as...
We wouldn't be at all surprised I have been a QS for 25 odd years.
